Problem installing SP10 in RTM 1.4 on LMS for Windows
smirandac
Hi, I can't install SP10 for RTM in my Windows 2000 server. The installer try to install in c:\program files, but I have installed RTM on a different partition. The installer don't have a "change" button for the destination of files.
rmushtaq
Level 8
Level 8
Installation on the same box with LMS is not recommended
smirandac
it´s ok, it was just a wrong user problem, the right user for intallation is the secured user ngenius for access to the destination folder
thanks
