03-28-2007 12:35 AM
I have problem when I try to do backup but only scheduled backup (daily, weekly or monthly). Message which I receive: "Cannot read schedule info. Please look into the log files."
Immediate backup works ok.
Do anybody knows where is reason this problem?
Solved! Go to Solution.
03-28-2007 07:30 AM
Check and make sure that casuser has correct rights:
Windows:
Under your Security Policy casuser needs to have:
1. log on as a batch job
2. log on locally
3. Access this computer from the network
and Full Control for the ..\CSCOpx folder,
all subdirectories and files.
Solaris:
Make sure casuser has cron access. You may need to be add casuser to the cron.allow file or else jobs won't get scheduled
03-28-2007 07:30 AM
Windows:
2. log on locally
Solaris:
03-29-2007 01:08 AM
Thanks for your answer.
Problem was with casuser's permision to crontab.
