10-04-2006 12:40 AM
Good morning,
I have problem with changing password in db CMF. Utility dbpasswd.pl has written me this errors.
INFO: Start changing password for database 'cmf'...
Starting database engine cmfEng
ERROR: Failed to Start Database 'cmf' because: Could not connect to engine 'cmfEng' on 'cmfDb' in Bulk mode. Check user id and passwords
ERROR: Failed to update new userinfo into database.
Stopping database engine cmfEng
Unable to stop database server -- Invalid user ID or password.
ERROR: Failed to stop the database engine with old password: .
ERROR: Failed change password for database 'cmf'.
Please see log file /var/adm/CSCOpx/log/dbpwdChange.log for details.
Has anybody any idea, what to do?
Thank you
sarka
10-04-2006 07:10 AM
What version of LMS is this?
Also, if you run it with the following syntax does it work:
"dbpasswd.pl dsn=cmf encryption=yes npwd=
10-13-2006 12:51 AM
Thank you for advise.
I had edited the files with passwords and it helps.
