Bookmark
Subscribe
1236
Problem with changing password for db CMF
stesarova
Good morning,
I have problem with changing password in db CMF. Utility dbpasswd.pl has written me this errors.
INFO: Start changing password for database 'cmf'...
Starting database engine cmfEng
ERROR: Failed to Start Database 'cmf' because: Could not connect to engine 'cmfEng' on 'cmfDb' in Bulk mode. Check user id and passwords
ERROR: Failed to update new userinfo into database.
Stopping database engine cmfEng
Unable to stop database server -- Invalid user ID or password.
ERROR: Failed to stop the database engine with old password: .
ERROR: Failed change password for database 'cmf'.
Please see log file /var/adm/CSCOpx/log/dbpwdChange.log for details.
Has anybody any idea, what to do?
Thank you
sarka
David Stanford
What version of LMS is this?
Also, if you run it with the following syntax does it work:
"dbpasswd.pl dsn=cmf encryption=yes npwd="
Thank you for advise.
I had edited the files with passwords and it helps.
