06-17-2009 12:38 AM
Good Morning
I'm just installed the version LMS 3.0 on my server SunSolari 10 following all the instructions on the installation guide.
At the end of the installation I connected the tool by Http and till now all was working fine.
When I tried to configure the "Server Setup" by Cisco Works Assistant I got this message : " Reachable(CiscoWorks Assistant does not support the installed Common Services version.).
Strange errors, because I have installed the LMS by Cisco DVD where the version of the applications should be the right one, infect I checked them found out that the Version of CM is 3.1 that is supported by CiscoWorks Assistant 1.0.
Can you help me because I'm not able to find a solution
Thanks so much in advance
Solved! Go to Solution.
06-17-2009 05:45 AM
06-17-2009 05:45 AM
11-25-2013 09:33 PM
As iam getting the same problem mentioned above.but iam not able to open the link mentioned above properly.So plz provide me the solution and reply to this as soon as possible!!
