Problem with dynamic user tracking set up
marshajr
When I try to configure dynamic user tracking, I get an error message in the config job:
% Invalid input detected at '^' marker
for the command:
snmp trap mac-notification added.
This is trying to configure a port on a 3750. I believe the command string should be:
snmp trap mac-notification change added.
Is this a known problem, and is there a fix?
I am currently running Campus Manager 5.2.1 under LMS 3.2
Gaganjeet Chug
Level 4
Level 4
Yes you are correct in your observation. Bug had been filed for this which is release pending status.
BUG ID = CSCtq00798
You may not be able to see the detials for this bug at the moment.
The issue is similar to CSCsq45337 = Dynamic UT trap listener configuration does not work with 12.2(40)SE
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsq45337
Gaganjeet
Gaganjeet Chug
Level 4
Level 4
BUG ID = CSCtq00798
Gaganjeet
