Problem with ip address in L3 switch port
meet_mkhan
Hi Experts,
I am getting error when trying to give ip address to 3550 switch interfcae
check below error
SW-3500(config)#
SW-3500(config)#int fa0/7
SW-3500(config-if)#no swi
SW-3500(config-if)#no switchport mo
SW-3500(config-if)#no switchport mode
SW-3500(config-if)#no switchport acce
SW-3500(config-if)#no switchport access vla
SW-3500(config-if)#no switchport access vlan
SW-3500(config-if)#ip address 1.1.1.1 255.0.0.0
% Invalid input detected at '^' marker.
SW-3500(config-if)#^Z
SW-3500#
00:15:38: %SYS-5-CONFIG_I: Configured from console by consolesh ver
SW-3500#sh version
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5.2)XU, MAINTENANCE IN
TERIM SOFTWARE
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 17-Jul-00 18:29 by ayounes
Image text-base: 0x00003000, data-base: 0x00301F3C
ROM: Bootstrap program is C3500XL boot loader
SW-3500 uptime is 15 minutes
System image file is "flash:c3500XL-c3h2s-mz-120.5.2-XU.bin"
cisco WS-C3524-XL (PowerPC403) processor (revision 0x01) with 8192K/1024K bytes
of memory.
Processor board ID FAA0502M1GG, with hardware revision 0x00
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:04:C1:C1:F1:C0
Motherboard assembly number: 73-3904-11
Power supply part number: 34-0851-02
Motherboard serial number: FAB0501B21D
Power supply serial number: PHI044502HF
Model revision number: A0
Model number: WS-C3524-XL-EN
System serial number: FAA0502M1GG
Configuration register is 0xF
SW-3500#
2 Accepted Solutions
shajakhan85
3524 switch does not support L-3 functionality.
Shajakhan.K
In your original post is output from show version and it is quite clear that this switch is a 3524
of memory.
Rick
Rick
8 Replies 8
Rejohn Cuares
Level 4
Level 4
Enter "no switchport" under an interface.
Please rate replies and mark question as "answered" if applicable.
         Thanks for your soon reply i appied no switchport
               but it is incomplete coomand.Please check below config
% Incomplete command.
SW-3500(config-if)#no switchport ?
  access    Set access mode characteristics of the interface
  mode      Set trunking mode of the interface
  multi     Set characteristics when in multi-VLAN mode
  priority  Set 802.1p priorities
  trunk     Set trunking characteristics of the interface
  voice     Voice appliance attributes
shajakhan85
Shajakhan.K
     I am dealing with 3550 switch and its L3 switch
of memory.
Rick
Rick
Sorry i dint check properly so what is the solutin for it ?can i change ios to assign ip address.
This question was also posted in another forum and in that forum we have provided the answer that it is a limitation of the switch. So changing IOS would not provide a solution. The solution is to use a different switch which does have support for layer 3 processing.
Rick
Rick
Thanks guys for reply and all is extremely helpful.
