Problem with quality of service configuration
Tommy Svensson
Hi.
I dont know if this is the right section for my problem, but anyways.
Im having problems with my QoS configuration, i want to guarantee some of the bandwidth for a bunch of protocols and i cant seem to get it right, im new at configuring this type of service so i would need a little help.. My Internet connections is 10/10 Mbit.
Regards Tommy Svensson
R1(config-if)#do show run
Building configuration...
Current configuration : 9541 bytes
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
ip dhcp excluded-address 10.10.100.1 10.10.100.49
ip dhcp excluded-address 10.10.100.251 10.10.100.254
ip dhcp excluded-address 10.10.10.1 10.10.10.49
ip dhcp excluded-address 10.10.10.251 10.10.10.254
ip dhcp excluded-address 10.10.20.1 10.10.20.49
ip dhcp excluded-address 10.10.20.251 10.10.20.254
ip dhcp excluded-address 10.10.1.1 10.10.1.49
ip dhcp excluded-address 10.10.1.251 10.10.1.254
ip dhcp excluded-address 10.10.2.1 10.10.2.49
ip dhcp excluded-address 10.10.2.251 10.10.2.254
ip dhcp excluded-address 10.10.3.1 10.10.3.49
ip dhcp excluded-address 10.10.3.251 10.10.3.254
ip dhcp excluded-address 10.10.30.1 10.10.30.49
ip dhcp excluded-address 10.10.30.251 10.10.30.254
ip dhcp pool Management
import all
network 10.10.100.0 255.255.255.0
domain-name Tedact.local
dns-server 192.168.98.2
default-router 10.10.100.1
ip dhcp pool Company10
import all
network 10.10.10.0 255.255.255.0
domain-name tedact.local
default-router 10.10.10.1
ip dhcp pool Company20
import all
network 10.10.20.0 255.255.255.0
default-router 10.10.20.1
ip dhcp pool VLAN_1_DHCP
import all
network 10.10.1.0 255.255.255.0
default-router 10.10.1.1
import all
network 10.10.2.0 255.255.255.0
default-router 10.10.2.1
ip dhcp pool Company3
import all
network 10.10.3.0 255.255.255.0
default-router 10.10.3.1
ip dhcp pool Company30
import all
network 10.10.30.0 255.255.255.0
default-router 10.10.30.1
no ip bootp server
ip domain name tedact.local
ip name-server 192.168.98.2
ip tcp synwait-time 10
ip ssh authentication-retries 5
class-map match-any QoS-Viktig_trafik
match protocol ssh
match protocol http
match protocol secure-http
match protocol secure-ftp
match protocol secure-ldap
match protocol secure-nntp
match protocol secure-imap
match protocol secure-pop3
match protocol secure-irc
match protocol secure-telnet
match protocol imap
match protocol pop3
match protocol smtp
match protocol irc
match protocol telnet
match protocol xwindows
match protocol rtp audio
match protocol rtp video
match protocol tftp
match protocol dns
class-map type inspect match-any VLAN_TO_WAN_CLASS
match protocol icmp
match protocol echo
match protocol http
match protocol https
match protocol pop3
match protocol pop3s
match protocol smtp
match protocol imap
match protocol imaps
match protocol imap3
match protocol ftp
match protocol ssh
match protocol dns
match protocol h323
match protocol tftp
match protocol ntp
match protocol irc
match protocol ircs
match protocol ldap
match protocol snmp
policy-map type inspect VLAN_TO_WAN_POLICY
class type inspect VLAN_TO_WAN_CLASS
inspect
class class-default
drop
policy-map QoS-Viktig_trafik-POLICY
class QoS-Viktig_trafik
priority percent 25
zone security VLAN10_ZONE
zone security VLAN20_ZONE
zone security VLAN30_ZONE
zone security VLAN100_ZONE
zone security WAN_ZONE
zone-pair security VLAN_10_TO_WAN source VLAN10_ZONE destination WAN_ZONE
service-policy type inspect VLAN_TO_WAN_POLICY
zone-pair security VLAN_20_TO_WAN source VLAN20_ZONE destination WAN_ZONE
zone-pair security VLAN_30_TO_WAN source VLAN30_ZONE destination WAN_ZONE
zone-pair security VLAN_100_TO_WAN source VLAN100_ZONE destination WAN_ZONE
interface GigabitEthernet0/0
description NOT USED
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/0.1
description VLAN_1_Native
encapsulation dot1Q 1 native
ip address 10.10.1.1 255.255.255.0
ip nat inside
no cdp enable
interface GigabitEthernet0/0.2
description VLAN_2_Company2
encapsulation dot1Q 2
ip address 10.10.2.1 255.255.255.0
ip nat inside
no cdp enable
interface GigabitEthernet0/0.3
description VLAN_3_Company3
encapsulation dot1Q 3
ip address 10.10.3.1 255.255.255.0
ip nat inside
no cdp enable
interface GigabitEthernet0/0.10
description VLAN_10_Company10
encapsulation dot1Q 10
ip address 10.10.10.1 255.255.255.0
ip nat inside
zone-member security VLAN10_ZONE
no cdp enable
interface GigabitEthernet0/0.20
description VLAN_20_Company20
encapsulation dot1Q 20
ip address 10.10.20.1 255.255.255.0
ip nat inside
zone-member security VLAN20_ZONE
no cdp enable
interface GigabitEthernet0/0.30
description VLAN_30_Company30
encapsulation dot1Q 30
ip address 10.10.30.1 255.255.255.0
ip nat inside
zone-member security VLAN30_ZONE
no cdp enable
interface GigabitEthernet0/0.100
description VLAN 100 Management
encapsulation dot1Q 100
ip address 10.10.100.1 255.255.255.0
ip nat inside
zone-member security VLAN100_ZONE
no cdp enable
interface GigabitEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
shutdown
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/2
description $ETH-WAN$
bandwidth 10000
bandwidth receive 10000
ip address 192.168.98.205 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
zone-member security WAN_ZONE
duplex auto
speed auto
no mop enabled
service-policy output QoS-Viktig_trafik-POLICY
ip nat pool with_overload 192.168.98.205 192.168.98.205 prefix-length 24
ip nat inside source list 7 pool with_overload overload
ip route 0.0.0.0 0.0.0.0 192.168.98.254
logging trap debugging
access-list 7 permit 10.10.10.0 0.0.0.255
access-list 7 permit 10.10.20.0 0.0.0.255
access-list 7 permit 10.10.100.0 0.0.0.255
access-list 7 permit 10.10.30.0 0.0.0.255
access-list 7 permit 10.10.1.0 0.0.0.255
access-list 7 permit 10.10.2.0 0.0.0.255
access-list 7 permit 10.10.3.0 0.0.0.255
Tommy Svensson
Anyone who could possibly know the awser to this one?
It would be much apreciated.
