04-15-2019 08:59 AM
Hi averyone
i had the problem with the new release with 3.8.8 cisco WS-C4510R+E. After this update the allarm with "Nagios" go up, but the service working fine. I have more of 150 allarm conecting between Cisco and Nagios. But only 100 go up, and the 50 stay down.
I have configured the snmp like before :
snmp-server community Publica RO
snmp-server community Privada RW
But the problem persists. I don't know if the problem is the new release or in Nagios i need to change somethig
Any idea what it can be?
THX all
04-15-2019 10:09 AM
@sistemas.p hello,
which version of snmp are you using?
Does your snmp configuration has an acl applied?
Does your snmp configurarion has traps enabled?
Could your provide a configuration of your snmp?
Please, input here output of commands:
show snmp
show runnning-config | begin snmp
04-16-2019 08:37 AM
Hi Jaderson
this is the our snmp version
VSSCORE1#sh snmp
Chassis: FXS1751Q2QE
286523 SNMP packets input
0 Bad SNMP version errors
56285 Unknown community name
0 Illegal operation for community name supplied
0 Encoding errors
227571 Number of requested variables
0 Number of altered variables
233432 Get-request PDUs
0 Get-next PDUs
0 Set-request PDUs
0 Input queue packet drops (Maximum queue size 1000)
229844 SNMP packets output
0 Too big errors (Maximum packet size 1500)
2273 No such name errors
0 Bad values errors
0 General errors
229844 Response PDUs
0 Trap PDUs
SNMP global trap: disabled
SNMP agent enabled
SNMP logging: disabled
VSSCORE1#
VSSCORE1#sh running-config | begin snmp
snmp-server community PuertPublica RO
snmp-server community PuertEscritura RW
snmp-server community PDEtrap RO
ipv6 access-list VSL-IPV6-ROUTING
permit ipv6 any FF02::/124
banner motd ^CC
El acceso a este sistema propiedad de ha quedado registrado.
Necesita tener autorizacion antes de usarlo, estando usted estrictamente limitado al uso indicado en dicha autorizacion.
El acceso no autorizado a este sistema o el uso indebido del mismo estC! prohibido y es contrario a la Politica, Normativas y Procedimientos de Seguridad de Puertos del Estado, asi como a la legislacion vigente.
Cualquier revelacion de informacion interna de Puertos del Estado sin previa autorizacion podria estar incurriendo en una violacion de la Normativa Interna de
que podria incluso suponer la posible comision de un delito o falta. No mail.
^C
line con 0
login local
stopbits 1
line vty 0 4
exec-timeout 180 0
login local
line vty 5 15
login local
monitor session 1 source interface Gi2/1/35
monitor session 1 destination interface Gi2/1/26
monitor session 1 filter packet-type good rx
monitor session 2 source interface Gi2/1/35
monitor session 2 destination interface Gi1/1/9
monitor session 2 filter packet-type good rx
module provision switch 1
chassis-type 69 base-mac 3C08.F6BF.5E00
slot 1 slot-type 385 base-mac 7426.AC47.F5F8
slot 2 slot-type 385 base-mac D072.DCB1.5834
slot 3 slot-type 387 base-mac D072.DCD5.CC3C
slot 4 slot-type 387 base-mac D072.DCFB.2C34
slot 5 slot-type 404 base-mac 3C08.F6BF.5E00
slot 7 slot-type 303 base-mac 0018.7380.2716
slot 8 slot-type 303 base-mac 0002.4B99.59AA
slot 9 slot-type 383 base-mac 18E7.2834.B9E4
module provision switch 2
chassis-type 69 base-mac 3C08.F6BF.5D40
slot 1 slot-type 385 base-mac D072.DCFB.6120
slot 2 slot-type 385 base-mac D072.DCFB.5EE0
slot 3 slot-type 387 base-mac B838.6175.5D78
slot 4 slot-type 387 base-mac D072.DCD6.0584
slot 5 slot-type 404 base-mac 3C08.F6BF.5D40
slot 7 slot-type 303 base-mac 001B.539B.7AC0
slot 8 slot-type 303 base-mac 0002.4B99.46A8
slot 9 slot-type 383 base-mac 6412.257C.D6D0
ntp server 172.20.22.16
end
VSSCORE1#
what could be the problem?
THX for all
04-16-2019 10:53 AM
@sistemas.p hello,
VSSCORE1#sh snmp
56285 Unknown community name << here your problem. Does your monitor has a community name configured properly?
0 Encoding errors
0 Get-next PDUs
0 Set-request PDUs
0 Bad values errors
0 General errors
0 Trap PDUs
SNMP agent enabled
VSSCORE1#
The community above need is the same on host that you has a monitor software instaled.
04-17-2019 01:32 AM
Hi jaderson,
I thing yes, Because the my monitor Nagios don't I changed the configuration.
you thing the monitor have more the 3 community configuracion ?
THX
