12-09-2011 03:14 AM
Hi everybody!
I have a problem with topology view in LMS 4.0. I have three Nexus 7010 devices: DC-CORE-SWN7K01, DC-CORE-SWN7K02 and DR-CORE-SWN7K01, each connect to the others that form a triangle. DR-CORE-SWN7K01 connects to others via CWDM. when use show cdp neighbor, the output shows a device are connected to the others correctly. But in topology network view Layer 2, there is only one link connect from DR-CORE-SWN7K01 to DC-CORE-SWN7K02 as shown as in the figure below.
Links connect from DR-CORE-SWN7K01 to
Some output of commands:
DC-CORE-SWN7K01
DC-CORE-SWN7K01# sh cdp nei
Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
S - Switch, H - Host, I - IGMP, r - Repeater,
V - VoIP-Phone, D - Remotely-Managed-Device,
s - Supports-STP-Dispute
Device-ID Local Intrfce Hldtme Capability Platform Port ID
DC-CORE-SWN7K02(JAF1528DLJD)
Eth3/1 141 R S I s N7K-C7010 Eth3/1
Eth4/1 150 R S I s N7K-C7010 Eth4/1
DR-CORE-SWN7K01(JAF1529DFGH)
Eth7/1 137 R S I s N7K-C7010 Eth3/1
DC-CORE-SWN7K01# sh run interface e7/1
interface Ethernet7/1
description <to DR-CORE-SWN7K01>
ip address 10.64.124.129/30
ip ospf authentication
ip ospf authentication-key 3 ae7c0e0b3f4daa38
ip ospf network point-to-point
ip router ospf 10 area 0.0.0.0
no shutdown
DC-CORE-SWN7K02
DC-CORE-SWN7K02# sh cdp nei
DC-CORE-SWN7K01(JAF1527DPDM)
Eth3/1 158 R S I s N7K-C7010 Eth3/1
Eth4/1 158 R S I s N7K-C7010 Eth4/1
Eth7/1 130 R S I s N7K-C7010 Eth3/2
DC-CORE-SWN7K02# sh run inter e7/1
ip address 10.64.124.133/30
no shutdown
DR-CORE-SWN7K01
DR-CORE-SWN7K01# sh cdp nei
Eth3/1 124 R S I s N7K-C7010 Eth7/1
Eth3/2 157 R S I s N7K-C7010 Eth7/1
DR-CORE-SWN7K01# sh run interface e3/1
interface Ethernet3/1
description < to DC-CORE-SWN7K01 E7/1 >
ip address 10.64.124.130/30
no shutdown
DR-CORE-SWN7K01# sh run inter e3/2
interface Ethernet3/2
description < to DC-CORE-SWN7K02 E7/1 >
ip address 10.64.124.134/30
no shutdown
Can anybody tell me what problem is? What reason for missing link in topology view?
Thanks and Best Regards
Truong Ngoc Khanh
12-09-2011 04:24 AM
You can try to delete all links between the core devices and launch a datacollection for the core devices.
Sometimes campus gets it right when you do this.
If that fails you probably need to remove and re-add the core devices from the DCR.
Cheers,
Michel
12-09-2011 04:39 AM
Thanks for ur reply Michel,
It doesnt work.:(. When I shutdown the port on DR-CORE connecto to DC-CORE-SWN7K02, there is no link displayed on network topology view. Should I install patch for topology services?
12-09-2011 04:45 AM
Shut the port ???
No, I mean in campus, select the links between the core devices and delete them.
Then run a data collection.
Cheers,
Michel
12-09-2011 04:57 AM
In Campus? I dont understand. You mean delete link directly on topology map and launch Data Collection
Truong Ngoc Khanh
12-09-2011 05:12 AM
Yes, delete the links in the map.
Cheers,
Michel
12-11-2011 11:47 PM
It still doesnt work. Is it impossible that NX-OS cause the miss link on topology views. Would you like to provide the other information of devices? In addition, the SFPs we use are modules of CWDM with diffirent wave-length. I wonder whethre they are the reason that Topology map cannot draw this link?
Any ideas?
Thanks and Best Regards,
Truong Ngoc Khanh
12-12-2011 01:33 AM
Sorry to hear that.
As far as I know the campus topology is based on CDP info. And since you see all the links in the CDP tables, so should campus.
I've seen campus getting it wrong a few times, especially when there was some repatching done, but until now, when I delete the devices and re-add these devices, the next data collection gets the links correct.
Cheers,
Michel
12-14-2011 07:43 PM
Hi Michel!
I have deleted and re-added 3 devices a thousand times but the link connect from DR-CORE-SWN7K01 to DC-CORE-N7K01 have not appeared. Is it the bug of topology with nexus combines with CWDM? CDP neighbor table appears correctly. So disappoint
12-14-2011 07:45 PM
By the way, when I disable the port connect from DR-CORE-SWN7K01 to DC-CORE-SWN7K02, there is no link connect from two sites displayed on topology map??? What the hell?
03-21-2018 12:23 AM
Making the directory \program files\java\jre6\lib\endorsed writable is already a security risk.
Making the whole java directory under full control is overdoing it.
If you investigated then you know where it it tries to write the jar's. Not need to open up the rest.
Your IT security people should validate this.
