Problems after upgrading LMS from 4.1 to 4.2.3
WildCard81
After the upgrade of the LMS we have the situation that all our deviced are visible in the subnet groups but not in "all devices".
When I want to launch an inventory collection the following message is displayed:
"ICSU0025: Problem with JRM. The JRM server may not be running. Check ICServerUI.log for more details. See the user guide Administration of CiscoWorks LMS for the log file location."
When I do a Discovery, the deviced are being discovered but they are unreachable.
And all the host names are changed into their IP addresses.
I can't seem to find the problem. Even after roaming the forum here.
I'm not able to pinpoint the exact cause of the problems...
Any ideas?
regards,
W
Saurav Lodh
Level 7
Level 7
Please have a look,
Please open a case with our TAC
Vinod Arya
Please share the output of NMSROOT\bin\pdshow from your server. It should tell if the process is really working or not.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Already did that, and JRM is running normally:
Process=JRM
State= Running normally
Process CTMJrmServer
Has ANIServer something to do with this?
Process= ANIServer
Sate= Running with busy flag set
don't know why it says with busy flag set
regards
Tom
That is a healthy normal state for ANIServer. I checked some similar cases and it seems most of them were transient and got resolved once daemon was reatarted.
I would suggest to follow this procedure once additionally :
> Stop Daemon manager
> Regenerate SSL certificate
> Do a transaction log for RME DB
> Start the daemon
For 2nd and 3rd check my this post for process :
https://supportforums.cisco.com/message/3597059#3597059
If this is Solaris/linux, for transaction log, check this link (under Recovering From a Server Crash).
-Thanks
