09-12-2008 12:33 AM
I use snmpwalk to check our switches. My problem is, i want to check wich interfaces are assigned to an etherchannel but i don't find the right oid.
09-18-2008 10:30 AM
The OID for the object âinterfaceâ is â1.3.6.1.2.1.2â
09-18-2008 11:23 PM
i checked this oid, but the output don't show me which interface is assigned to an etherchannel (port-channel), or am i blind?
06-06-2013 02:31 AM
I have found the SNMP to monitor if a port in a EtherChannel fails.
| dot3adAggAggregateOrIndividual |
http://ipmsupport.solarwinds.com/mibs/IEEE8023-LAG-MIB/item.aspx?id=dot3adAggAggregateOrIndividual
06-06-2013 06:47 AM
for PAgP I use this OID (pagpGroupIfIndex):
For LACP I'd need to do some research (IEEE8023-LAG-MIB dot3adAggEntry, CISCO-LAG-MIB).
Please let us know which channel-protocol your're using.
Hope that helps
Rolf
06-07-2013 05:47 AM
For LACP I found two interesting objetcts in IEEE8023-LAG-MIB:
IEEE8023-LAG-MIB::dot3adAggPortSelectedAggID.28 = INTEGER: 337
IEEE8023-LAG-MIB::dot3adAggPortSelectedAggID.82 = INTEGER: 337
IEEE8023-LAG-MIB::dot3adAggPortAttachedAggID.28 = INTEGER: 337
IEEE8023-LAG-MIB::dot3adAggPortAttachedAggID.82 = INTEGER: 337
ifName.28 = Gi2/4
ifName.82 = Gi3/10
ifName.337 = Po1
#show etherchannel 1 summary
Group Port-channel Protocol Ports
1 Po1(SU) LACP Gi2/4(P) Gi3/10(P)
Best regards
Rolf
