Problems configuring a Cisco 2511
choorky78
I just bought a 2511 since I started studying for CCNA recently, but I'm having trouble getting it to work.
I've tried most of the options on Internet and in the Cisco technotes, but obviously I'm doing something wrong.
Each time I try to go to the console of one of my other routers I get:
Trying 7th (10.1.1.7, 2007)...
% Connection timed out; remote host not responding
This is my current config:
Current configuration : 1599 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname R2511
logging rate-limit console 10 except errors
ip subnet-zero
no ip finger
no ip domain-lookup
ip host 1th 2001 10.1.1.1
ip host 2th 2002 10.1.1.2
ip host 3th 2003 10.1.1.3
ip host 4th 2004 10.1.1.4
ip host 5th 2005 10.1.1.5
ip host 6th 2006 10.1.1.6
ip host 7th 2007 10.1.1.7
ip host 8th 2008 10.1.1.8
interface Loopback0
ip address 10.1.1.200 255.255.255.0
interface Ethernet0
no ip address
shutdown
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
ip classless
no ip http server
line con 0
transport input none
line 1
session-timeout 10
location 1th
no exec
exec-timeout 0 0
transport input all
stopbits 1
line 2
session-timeout 10
location 2th
no exec
exec-timeout 0 0
transport input all
stopbits 1
(line 3-8 removed )
line 9 16
line aux 0
line vty 0 4
end
Does anybody have suggestions?
glen.grant
How are you getting to these other addresses you have nothing configued on any of your ethernet or serial ports to get to these other addresses . If you are jsut trying to get to the devices hung off the console cables at the prompt try just typing 1th or 2th then hit enter and see what happens . You would not be able to telnet to these the way you have it setup .
spremkumar
Level 9
Level 9
hi
On your console config its configured as transport input none,u need to change that to transport input all or transport input telent.
also your line vtys arent configured properly,do enter password and login under line vty 0 4.
line vty 0 4
password cisco
login
regds
glen.grant
The problem was that I should have used the loopback-ip.
It's working now.
