SQL Help with DBreader
GeorgeLarson
I am trying to do a left join in the sql statement, but it keeps erroring out. If I take out the left, it joins the tables, but I don't get all the data I want. Can someone tell me how to do a left join? Everything I have read on Sybase says the left join should work.
nhabib
Level 11
Level 11
What is the exact syntax of the statement that you are using?
SELECT dev_fqn.Device_Name, dev_domain.Device_Domain_Name
FROM dev_fqn LEFT JOIN dev_domain ON dev_fqn.Domain_Id = dev_domain.Domain_Id
This should bring up all the records from dev_fqn and if there is a matching record in dev_domain.
I exported all the tables from rme to access and can run this statement in access and it works fine.
If I take out the left keyword, then dbreader runs but I don't get all the records from dev_fqn table.
Try this one instead:
SELECT dev_fqn.Device_Name, dev_domain.Device_Domain_Name FROM dev_fqn LEFT OUTER JOIN dev_domain ON dev_fqn.Domain_Id = dev_domain.Domain_Id
That worked. Where do you find this stuff. I can find no reference for dbreader specific to CiscoWorks.
