Problems with LMS 4.0 using Routers
Wellington L
I have problems with LMS 4.0 to take the configuration and change it in the routers 1721 and 2801.
It's strange because in AP1232 and Catalyst 2950 i can do that.
I gave the commands below in the devices above :
snmp-server community COMUNIDADE-X  RW
snmp-server enable traps
snmp-server host <IP_Server> traps COMUNIDADE-X
Joe Clarke
It is not clear what problem you're seeing.  Is LMS failing to sync the archive from the device or push a new config to the device?  What exactly are you doing in LMS to reproduce this problem?  What error do you see?
