Problems with mib on routers Cisco 2610, 2801 and 1760
RonaldJCM
I am trying to monitor routers Cisco 2610, 2801 and 1760 with a monitoring software called zenoss. and I cant see on this devices the powersupply state, temperature sensor, fan state, i dont know if this models of routers cant support the monitoring of this component on the devices.
anybody know what can i do to monitoring this component? what kind of Oid I can use to get this components state?
mallwright
I suspect that these devices do not report detailed values.
A tip that may help is to do a "show env all" at the CLI.  From a device that does not have detaild values you will get something like this:
#sh env all
FAN is OK
Internal POWER supply is OK
RPS is NOT present
From a device that does have detailed values you will get something like this:
1#sh env all
FAN is OK
TEMPERATURE is OK
Temperature Value: 41 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 58 Degree Celsius
Red Threshold    : 68 Degree Celsius
SW  PID                 Serial#     Status           Sys Pwr  PoE Pwr  Watts
1  Built-in                                         Good
SW  Status          RPS Name          RPS Serial#  RPS Port#
1   Not Present     <>
Hopr this helps.
Mark.
Montitored by PRTG <http://http://www.paessler.com/>
Hi Mark,
Kindoy try to do snmpwalk from the NMS tool for the OID
1.3.6.1.4.1.9.9.13
I tried this in my lab and its working fine :-
nms-server#sh env all
FAN is OK
TEMPERATURE is OK
Temperature Value: 35 Degree Celsius
 2  Built-in                                         Good
2   Not Present     <>
nms-server#
C:\usr\bin>snmpwalk.exe -v 2c -c gagan 10.78.136.41 1.3.6.1.4.1.9.9.13
SNMPv2-SMI::enterprises.9.9.13.1.1.0 = INTEGER: 13
SNMPv2-SMI::enterprises.9.9.13.1.3.1.2.2005 = STRING: "SW#2, Sensor#1, GREEN
SNMPv2-SMI::enterprises.9.9.13.1.3.1.3.2005 = Gauge32: 36
SNMPv2-SMI::enterprises.9.9.13.1.3.1.4.2005 = INTEGER: 68
SNMPv2-SMI::enterprises.9.9.13.1.3.1.5.2005 = INTEGER: 0
SNMPv2-SMI::enterprises.9.9.13.1.3.1.6.2005 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.13.1.4.1.2.2004 = STRING: "Switch#2, Fan#1"
SNMPv2-SMI::enterprises.9.9.13.1.4.1.3.2004 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.13.1.5.1.2.2003 = STRING: "Sw2, PS1 Normal, RPS
NotE
xist"
SNMPv2-SMI::enterprises.9.9.13.1.5.1.3.2003 = INTEGER: 1
SNMPv2-SMI::enterprises.9.9.13.1.5.1.4.2003 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.13.2.1.0 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.13.2.3.0 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.13.2.4.0 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.13.2.5.0 = INTEGER: 2
SNMPv2-SMI::enterprises.9.9.13.2.6.0 = INTEGER: 2
Many Thanks,
Gaganjeet
thanks for your help Gaganjeet Chugh and Mark.
but I would like to know on which especific device model you proved sh env all. and what is IOS version of that devices?
Hi Ronald,
I tried this in our lab on image  12.2(53)SE.
More about the OID :-
ObjectciscoEnvMonMIB
OID1.3.6.1.4.1.9.9.13
MIB CISCO-ENVMON-MIB ;                                   -        View Supporting Images                                      this link will generate a new window
Description"The MIB module to describe the status of the Environmental
Monitor on those devices which support one.
You can view this link and click on the supporting images to check your device ios version.
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=1.3.6.1.4.1.9.9.13&translate=Translate&submitValue=SUBMIT
Many Thanks,
Gaganjeet
