09-17-2009 09:23 AM
I upgraded LMS from 3.0.1 to 3.2 and now getting errors like "DCR server is down or inaccessible", "JRM server is down or inaccessible", etc.
Where do I begin to troubleshoot these? I followed steps in another thread to delete the database logs and run a process on the DBs then restart. However that didn't work.
Thanks.
09-17-2009 09:24 AM
Post the output of the pdshow command. On what platform is LMS running?
09-17-2009 10:45 AM
09-17-2009 10:52 AM
The database monitors are in trouble, but all known bugs with that should have been fixed. Check the Windows Event Viewer for errors related to the dbmonitor.exe process. Also, post the TomcatMonitor.log and NameServerMonitor.log.
09-17-2009 11:01 AM
09-17-2009 11:10 AM
There appears to be a serious permissions problem on this server. Make sure the casusers group has Full Control over NMSROOT and all subdirectories.
09-17-2009 01:19 PM
That appears to have been the problem. Everything looks to be up at this point. I'm going to check the everything else to make sure it came over in the upgrade. Thanks!
