CISCO-MEMORY-POOL-MIB question
stephen-cook
Could anyone tell me what the "Driver text" memory pool is used for and why its memory usage would read 0?  I see it in some of the switch user guides but there is no explanation.
SNMPv2-SMI::enterprises.9.9.48.1.1.1.2.1 = STRING: "Processor"
SNMPv2-SMI::enterprises.9.9.48.1.1.1.2.2 = STRING: "I/O"
SNMPv2-SMI::enterprises.9.9.48.1.1.1.2.16 = STRING: "Driver text“
Thanks in advance,
Stephen
phiharri
Greetings Stephen,
The "Driver text" region is used to support dynamically loadable drivers for certain platform components, such as removable flash. It is expected for this memory region to report a low utilisation unless those drivers are in use.
Kind Regards,
/Phil
