09-08-2023 01:10 AM
We have a Cisco WS-C6509-E product.We want to use GUI for Cisco WS-C6509-E on Windows 10 Enteprise OS.
Which program can we use?.Can you send us the GUI EXE link?.
Thanks,Regards ...
NOTE:Cisco Network Assistan GUI can not work.Is Cisco Prime LAN Management Solution (LMS) true program?...
Suleyman
------------------ show version ------------------
Cisco IOS Software, s72033_rp Software (s72033_rp-IPBASEK9-M), Version 12.2(33)SXI1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sat 28-Mar-09 10:30 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
ciscoC6509 uptime is 3 weeks, 17 hours, 50 minutes
Uptime for this control processor is 3 weeks, 17 hours, 52 minutes
Time since ciscoC6509 switched to active is 3 weeks, 17 hours, 51 minutes
System returned to ROM by power cycle at 09:32:04 UTC Tue May 24 2022 (SP by power on)
System image file is "sup-bootdisk:s72033-ipbasek9-mz.122-33.SXI1.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.3) with 983008K/65536K bytes of memory.
Processor board ID SMC11160083
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
2 Virtual Ethernet interfaces
339 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
09-08-2023 02:18 AM - edited 09-08-2023 02:20 AM
These product is end of life and you have .bin file that do not have any GUI.
To access generally you need TAR image :
Cisco Prime Infra also end of Life
what exactly you looking to do with GUI ?
if i re-call decade back i rigns me belll i used - CiscoView device manager (not sure that existing any more)
