We are setting up MRTG to monitor the firewall interface usages.
snmp-server host eof-cth 10.33.192.25 community ***** version 2c udp-port 161
snmp-server host ABCD 10.33.192.25 community ***** version 2c udp-port 161
no snmp-server location
no snmp-server contact
snmp-server community *****
It doesn't work properly. the firewall have 4 active interfaces that normally have traffic 100 Mbps. But the result on MRTG shows only one interface using around 400 Mbps.
Could you advise?
My firewall model is:
Cisco Fire Linux OS v6.6.0 (build 37)
Cisco Firepower 2110 Threat Defense v6.6.0 (build 90)
Loc
- Are you sure you are monitoring the correct and or active-used interfaces ? You may want to snmp walk ifOperStatus from the IF-MIB, and correlate required interface-oid's accordingly.
M.
