Push configs with LMS 3.2.1
rshum
What module is used to push configurations in LMS 3.2.1?
Vinod Arya
RME is the module used to archive and push configurations. You can quick deploy full configuration from config viewer and you can make and deploy small configuration changes using NetConfig.
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
