QOS Packet tracer
Jeremy10
Hello, I sincerely apologize if I asked at the wrong place to post my questions. I am currently having difficulties with implementing QoS in packet tracer. We are tasked to implement Netflow for my routers and the direction I chose to use is from AR1 to AR2 ( According to my packet tracer file) to see the bandwidth consumption and have a capacity planning for my network diagram followed by implementing QoS. Our requirements for QoS are: "
1) Other traffic can be restricted to a maximum of 100kbps at all time
2) During congestion, minimum bandwidth can be guaranteed for the relevant applications
3) VoIP applied with QoS control policy delivered with minimum delay and improved jitter
Is it necessary to set a priority number for all of the requirements? Or is giving each class-map a certain amount of bandwidth enough? Do "Other traffic" refers to "UDP-OTHER" in ip cache flow? How do we know when to use cs3, cs2, af12, af 23 etc...? All I know is that a higher number will be dropped first ( eg; af23 will be dropped first compared to af22 and af 31 will be dropped first compared to af 22) I am really sorry but I am quite confused and I have no idea on how to start implementing QoS as this is my first time implementing it.. I hope that someone will be kind enough to at least give me a guideline
pmckenzie
Level 3
Level 3
If you go into packet tracer samples there is a QOS set up already for you to look at
Here is a snippet
class-map match-all critical
match protocol eigrp
class-map match-any interactive
match protocol telnet
match protocol ssh
class-map match-any web
match protocol http
policy-map markingpolicy
class critical
set precedence 7
class interactive
set precedence 5
class web
set precedence 3
interface Serial0/0/0
ip address 172.16.12.1 255.255.255.0
tx-ring-limit 1
service-policy output markingpolicy
hold-queue 1 out
There are worlds out there where the sky is burning, where the sea's asleep and the rivers dream, people made of smoke and cities made of song. Somewhere there's danger, somewhere there's injustice and somewhere else the tea is getting cold" Dr Who
Jeremy10
Hi, thanks for replying. Sorry for the late reply. I have a better understanding of QOS configurations in general now than before so I have attempted my first QOS config. Heres my configuration:
class-map match-any VOIP_DATA
match protocol rtp
match ip dscp ef
class-map match-any VOIP_control
match protocol h323
match protocol skinny
match ip dscp cs3
class-map match-any application
match protocol tftp
match protocol pop3
match protocol smtp
match protocol dns
match ip dscp af21
class-map match-any WEB
match protocol http
match protocol https
class-map match-any NM
match protocol ntp
match protocol icmp
match protocol syslog
match protocol snmp
match protocol rip
match ip dscp cs2
policy-map SetMK
class VOIP_DATA
set ip dscp ef
class VOIP_control
set ip dscp cs3
class application
set ip dscp af21
class WEB
set ip dscp af11
class NM
set ip dscp cs2
policy-map SetBW
class VOIP_DATA
bandwidth 300
class VOIP_control
bandwidth 100
class NM
priority 100
class WEB
bandwidth 100
class application
bandwidth 150
interface Loopback0
ip address 192.168.64.12 255.255.255.255
interface FastEthernet0/0
ip flow egress
ip address 10.32.77.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 192.162.30.1 255.255.255.0
interface FastEthernet0/0.40
encapsulation dot1Q 40
ip address 192.162.40.1 255.255.255.0
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
bandwidth 800
ip flow ingress
ip address 10.32.70.134 255.255.255.252
clock rate 2000000
interface Serial0/0/1
no ip address
clock rate 2000000
shutdown
May I ask why is it that when I tried to type the command " service-policy output SetBW" in s0/0/0 it shows "
I/f Serial0/0/0 class application requested bandwidth 150 (kbps), available only 0 (kbps)"? I checked my int s0/0/0 interface and it says that it has an available bandwidth of 600kbps, so I am unsure why it shows an error?
