VPC Trunks - Limit VLANs at Port Channel Interface AND Ethernet Port?
CiscoMedMed
When creating a port channel on Nexus (part of a VPC pair), do you restrict VLANs
at both the Ethernet interface *and* the port channel interface? Or just one or the other?
Thank you.
interface port-channel30
switchport mode trunk
switchport trunk allowed vlan 1,102,104
speed 40000
duplex full
vpc 30
interface Ethernet2/3
spanning-tree port type network
duplex full
channel-group 30 mode active
balaji.bandi
It all depends on order of operation.
Technically once you assign the interface to port-channel and Later configure port-channel configuration it will be sufficient.
But worth cross-checking is the interface got the right config what you configured on port-channel is the same on interface too.
BB
balaji.bandi
BB
