10-16-2008 11:15 AM
I am wondering if there are any trap definition for Qos Traffic monitoring.
We have our Performance Monitoring tool that provide stats per classMap but I am wondering How can I generates trap directly from the routers when we drop packets.
we have cisco GSR SY4
rgds
Abdel
10-21-2008 07:48 AM
It doesn't look like it can send traps, but you can always use EEM:
snmp-server enable traps event-manager
event manager applet qos_trap
event snmp oid [oid-from-CISCO-CLASS-BASED-QOS-MIB] get-type exact entry-op ge entry-val [alert-above-this-threshold] exit-op le exit-val [disarm-below-this-threshold] poll-interval 60
action 101 snmp-trap strdata "[oid-from-CISCO-CLASS-BASED-QOS-MIB] crossed [alert-above-this-threshold]"
04-16-2019 06:58 PM
so in the above command the threshold values are the number of packets dropped (values in the square bracket) and how do I determine the oid on nexus devices (7K)? will the oid be different on different interfaces?
thank you
Kerim
