Qos traps
abdel.bidar
I am wondering if there are any trap definition for Qos Traffic monitoring.
We have our Performance Monitoring tool that provide stats per classMap but I am wondering How can I generates trap directly from the routers when we drop packets.
we have cisco GSR SY4
rgds
Abdel
yjdabear
It doesn't look like it can send traps, but you can always use EEM:
snmp-server enable traps event-manager
event manager applet qos_trap
event snmp oid [oid-from-CISCO-CLASS-BASED-QOS-MIB] get-type exact entry-op ge entry-val [alert-above-this-threshold] exit-op le exit-val [disarm-below-this-threshold] poll-interval 60
action 101 snmp-trap strdata "[oid-from-CISCO-CLASS-BASED-QOS-MIB] crossed [alert-above-this-threshold]"
so in the above command the threshold values are the number of packets dropped (values in the square bracket) and how do I determine the oid on nexus devices (7K)? will the oid be different on different interfaces?
thank you
Kerim
