11-08-2007 06:44 AM
With the authPriv user if you don't explicitly assign a OID to that user then is it a "this user can write to any table" type thing? I was just kind of curious how that worked. Thanks in advance!
11-08-2007 10:33 AM
By default, the user will be read-only. You will need to assign a write view to the user before they will be able to set objects.
Log in to Community
