02-21-2015 12:02 PM
Hi again Experts,
I was quite surprised when I found this in the release notes for PI2.2.1:
"Device 360° View - A new icon labeled as Connect to Device is added to the left of Alarm Browser icon."
I have now installed the patch and this is how my Device 360 looks like, no "Connect to Device":
Have I misunderstood something or has my upgrade failed? My login screen still says 2.2.0 but under Installed updates I do find 2.2.1 Maintenance Release.
Has anyone got this new icon in the Device 360 view?
Johan
02-23-2015 08:05 AM
I can confirm that a new icon shows up just to the left of the Alarm Browser icon on the top row that allows you to open a telnet, ssh, http or https connection to the device. Interestingly enough, my splash screen says the same as yours 2.2.0 but I have successfully updated to 2.2.1
If you go into Administration > Software Update you should see the status if the Maintenance release and POODLE Fix. However, if you haven't yet upgraded yet, I would suggest holding off as the update has broke the entire software imaging portion of PI for myself and a few others. I suppose this is the last time I apply a patch the day it's released.
02-23-2015 10:53 AM
Thanks for your guidance and confirmation of the Connect to Device icon.
I'l guess this means yet another TAC-case for me...
Johan
