Radius attribute DNS
ksAlec
Frequent Visitor
Frequent Visitor
I'm trying to send some kind of DNS-Server address to my ppp client.
Dial in via vpdn and aaa via radius provides e.g. Framed-IP-Address,
but it doesn't seem to forward any DNS information whatsoever.
Maybe the reason is that I haven't used the correct attribute, because I can't find any in the rfc dictionaries
maybe I need to add a parameter to my cisco configuration.
All I know is that debug radius doesn't show my DNS server.
Any ideas anyone?
8 Replies 8
I need it the other way round: We are the Service provider (LNS) and I need to send the dns server address to a dial-up Client, which is a fritzbox.
Configure DNS Servers Through IPCP « ipSpace.net blog
under the virtual-template of server use
ppp ipcp dns <primary>
under the interface of client use
ppp ipcp dns request
I think this what you need
MHM
ksAlec
Frequent Visitor
Frequent Visitor
I tried that, but it didn't work.
ppp ipcp dns x.x.x.x
and the Fritzbox still says DNS is 0.0.0.0
Using a "normal" provider, the Fritzbox does get DNS server addresses, so I guess the client isn't the problem.
Then try
PPP ipcp dns accpet <<- this under client
Also use below debug to check if Server send DNS or not
debug ppp negotiation
MHM
ksAlec
Frequent Visitor
Frequent Visitor
I couldn't see the ipcp DNS part while debugging my test client,
but now I get clients who try to access my DNS-Server, so something must have worked, just not for that one test FritzBox.
I'll probably keep testing next week...
*Aug 11 16:31:25.679: Vi3 IPCP: I CONFNAK [ACKsent] id 2 len 16
*Aug 11 16:31:25.679: Vi3 IPCP:    Address 101.101.101.102 (0x030665656566)
*Aug 11 16:31:25.679: Vi3 IPCP:    PrimaryDNS 4.2.2.2 (0x810604020202)
 the DNS must appear in this part of debug
MHM
ksAlec
Frequent Visitor
Frequent Visitor
I've found somewhere on the internet that it might not be possible to send dns-server information via radius. It said, that even if the radius sends that information it won't be forwarded. The only way is using a fixed dns-server via
If that is true, it's unfortunate because I'd want different ppp connections to use different dns-servers. I guess I could work around it though.
