Radius Question Multiple Devices
Cameron.Carlson
I am stuck. I can see where I create the Radius authentication on the Cisco side and on the Server Side. But I have to select a host source where the RADIUS request will come from. Does that mean I have to make a new RADIUS CLIENT on the server side for every device?
Hello @Cameron.Carlson
It is possible work with device group but it is up to your RADIUS permit this. Which RADIUS solution are you using?
-If I helped you somehow, please, rate it as useful.-
