REGEXP doubt
I have a doubt in using regexp in my eem script.
Can someone help me.
My Script:
event manager applet update-port-description
event neighbor-discovery interface regexp GigabitEthernet.* cdp add
action 1.0 cli command "enable"
action 2.0 cli command "config t"
action 3.0 cli command "interface $_nd_local_intf_name"
action 4.0 cli command "description $_nd_cdp_entry_name:$_nd_port_id [$_event_pub_time]"
Instead of applying this script to all the interfaces in my switch.
I would like to apply this only for interfaces between gi0/[1-5] and not to any other interfaces.
Can someone help me in modifying the below line in the script,
Recommendations and suggestions are welcome !!!
12 Replies 12
Seb Rupik
Hi there,
Try this:
event neighbor-discovery interface regexp (GigabitEthernet0\/[1-5]\s) cdp add
cheers,
Seb.
This Didn't work.
Script didn't apply to any of the ports.
Nishanth
hmmmm, maybe try it without the brackets:
event neighbor-discovery interface regexp GigabitEthernet0\/[1-5]\s cdp add
cheers,
Seb.
Yeah , I tried that without brackets.
Still the same.
maybe it doesn't like the escape character for the forward slash. try this one:
event neighbor-discovery interface regexp GigabitEthernet0.[1-5]\s cdp add
Still its a No.
interface regexp .*GigabitEthernet0/[0-9]+$ cdp add
This one worked, Still If I change the limit to gi0/[1-15] , It stopped working.
Check if you get some idea !
I didn't notice the .* you had at the beginning of the search. Does this work:
event neighbor-discovery interface regexp .*GigabitEthernet0.[1-5]\s cdp add
or
event neighbor-discovery interface regexp .*GigabitEthernet0/[1-5]\s cdp add
[0-15] won't work as it is not syntactically correct. Square brackets are for single character matches. If you wanted 0-15 you could use:
(0|1|2|3|4|5|6|7|8|9|10|11|12|13|14|15)
or
([0-9]|[1][0-5])
Both didn't work,
Help me understand the below one and help me on extending that to gi0/[1-15]
bah this is some poor mans regex support in EEM! I guess \s is not supported either!
try:
.*GigabitEthernet0/([0-9]|[1][0-5])+$
If that doesn't work I don't know what will. You can check everything I've offered is valid here:
www.regex101.com
EEM regexp in the ED and in applets is limited to POSIX basic regexp support.  So to match a space, use [[:space:]].  The Perl-compatible \FOO will not work.
Hi Joe,
Do you have a link for the most authoritative Cisco doc on EEM equivalent regex voodoo??
cheers,
Seb.
In general, the syntax described at https://www.regular-expressions.info/posix.html will work within applets.  Tcl supports Tcl-compliant REs.
