Remote connection between to network
Hezqeel
Hi Gentlemen,
  • I have a main primary network which is a modem (192.168.1.1) connected to a WAN network and supply an internet to my house. I connected another modem as secondary to the main modem through Ethernet with ip address 192.168.0.1.
    How can I connect from a device in the primary network remotely to a device in the secondary network? As both devices got different ip address 192.168.1.34 and 192.268.0.7
Mark Elsen
  - When using two modems , you may not use the DHCP service on the secondary modem (turn it off in it's configuration) , to avoid address conflicts  ; so that the clients can only see one authoritative DHCP server (on the primary)
 M.
