link aggregation
Brahim dias
Sure! Here's the translation:
"I would like to know if it is possible to have 6 or 12 sub-interfaces in one port channel, and why."
6 Replies 6
Port-channel as physical interface you can have as much as you can of subinterface' and it limit by SW vlan tag  if SW vlan support up to 1023 then you can config up to 1023 (except some reserved vlan).
Note:- Some sw support up to 4093 vlan.
MHM
I would like to know if it is possible to have 5, 7, or 9 sub-interfaces in one port channel."
Sure no problem at all
MHM
As far as I know, port-channel interfaces don't have different limitations vs. other interfaces that support subinterfaces.
As to your OP "why", for the same reasons you would use subinterfaces, although I think it much more likely a L3 switch port-channel would be a trunk using SVIs and unsure a L3 switch would even support subinterfaces.
Joseph W. Doherty
BTW, you're not confusing port-channel physical interfaces with interface logical subinterfaces?
Okay, thank you for the answer.
I have an additional question. I would like to know if "mode on" is one of the protocols for link aggregation. How is it different from LACP and PAgP? Can it be used with all products?
