Removing Backup Repository FTP profiles
hyochum
Does anybody out there know how to remove from the NCS Backup screen a FTP repository that doesn't work?
I am trying to replace it with correct settings but am unable to.
hyochum
Answering my own post Hopefully this can help someone.
There is no option to remove repositories in the GUI
You must go to the CLI an type in the following:
admin#sh run | begin repository (this will list out the repositorys in your config)
admin#no repository <repository name> (this will remove the repository and any settings associated with it)
admin# sh run |begin repository (this will list out the repositorys that remain after the repository was removed)
admin#exit
admin# copy run start
I've wondered how to do this for about as long as we've been runing NCS/CPI.
Only issue I had with is is that the no repository commands need to be run in config mode. (at least in CPI 1.3)
Thanks!!!
