ciscoworks 4.2 - dfm email issue
secureIT
Level 4
Level 4
Hi Cisco Team,
Dfm email alerts are not coming though it was configured properly.
Did a wireshark pcap and below is the info taken from wireshark.
Command: MAIL FROM:<itreports.alerts@mycompany.com>\r\n
Command: RCPT TO:<network.support@mycompany.com>\r\n
Response: 550 5.7.1 Unable to relay for network.support@mycompany.com\r\n
Response code: Requested action not taken: mailbox unavailable (550)
Response parameter: 5.7.1 Unable to relay for network.support@mycompany.com
Im able to telnet to smtp server on port 25.
ciscoworks ip and smtp server ip are in the same pvt ip range.
Can you pls help.
19 Replies 19
AFROJ AHMAD
Hi Rajesh,
If you are  running LMS on windows then try to disable the Windows Firewall and see if you get emails.
Also share the SMTP.log (NMSROOT\CSCOpx\log)
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hi Afoz,
Please find the attached smtp.log
regards
Rajesh
secureIT
Level 4
Level 4
Thanks Afroz
I will check this and reply to you.
Sent from Cisco Technical Support Android App
Hi Rajesh,
logs looks fine.
[ Thu Jan 09 12:01:12 IST 2014 ] INFO   [Util : sendMail]  : sendMail()  - Starts
[ Thu Jan 09 12:01:12 IST 2014 ] INFO   [Util : sendMail]  : SMTP Server:hm02sql01.mycompany.com
[ Thu Jan 09 12:01:12 IST 2014 ] INFO   [Util : sendMail]  : Date:Thu, 9 Jan 2014 12:01:12 +0530
[ Thu Jan 09 12:01:12 IST 2014 ] INFO   [Util : sendMail]  : From ID:network.support@mycompany.com
[ Thu Jan 09 12:01:12 IST 2014 ] INFO   [Util : sendMail]  : To ID:
[ Thu Jan 09 12:01:12 IST 2014 ] INFO   [Util : sendMail]  : Subject:Job Id:1004.262, Status:Failed(25), Application:SysInvPoller, Run Type:Daily
[ Thu Jan 09 12:01:12 IST 2014 ] INFO   [Util : sendMail]  : sendMail()  - Ends
according to logs ..email was sent
***Test an email on a new Email address..
Thanks-
Afroz
But still i am not getting mails from ciscoworks..
do you need anything else ?
Hi  Rajesh,
Are you getting emails for other jobs ?
so far we hv configured only dfm to send email alerts.
but other servers are configured and getting email alerts from other servers(other vendors) to this smtp server.
you need any other info please update..
Hi Rajesh,
Could you check the smtp configuration and share the page by page screenshot from the following location:-
Admin > Network > Notification and Action Settings.
Make sure you have the same smtp server entry in the following two locations:-
Admin > Getting Started > System Settings
Admin > System > SMTP default Server
Share the screen shot from the above location as well.
Hi Syed,
im not at all getting email alerts from any of the modules..
Pls find the attached screenshots for your reference.
Default smtp server in both the pages are the same.
regards
Rajesh
Please check if SMTP server is properly configured on regdaemon.xml. You can share that file as well. Also, just check there is no duplicate entry for DFM Notifications.
Gracias
George
In addition to what Joe has suggested, please check the smtp.log when you generate an alert.
the log is located at NMSROOT\log.
Syed Khalid
Note:- NMSROOT is the LMS install directory.
Hi Syed,
I had already shared the logs in this thread.!!
regards
Rajesh
It seems the smtp stopped logging events sicen Jan 9. Did the emails stopped coming from Jan 9 2014? Please share the regdaemon.xml file from NMSROOT\MDC\etc.
Also redo the smtp server in the notification and action settings.
Syed Khalid
Hi Syed, this was the old smtp log.
i will share regdaemon.xml and reconfigure smtp.
anyother details you required ??
Infact, RME syslog email automation is also not sending any mail...
