Request - SNMPv3
aguante_boca
Dear Fellows,
I have been reading about SNMPv3 and its features for security.
Could you please confirm me if the next steps are correct?
1) Defining a view:
router(config)#snmp-server view readview internet included
2) Creating a group:
router(config)#snmp-server group readonly v3 auth read readview
3) Creating a user:
router(config)#snmp-server user user1 readonly v3 auth md5 password1
4) Createing the user at the SNMP Manager.
Is correct what is written above ?
Moreover, I would like to know if there is any chance to obtain the username and password of the point 3) from a TACACS server or RADIUS server?. The idea is that there is no need to create a new user locally. So that, the users and passwords could be obtained from a TACACS or RADIUS?
Thanks you in advanced!.
Vinod Arya
Your configuration looks correct and it should work!
At this time there is no way to use RADIUS, TACACS+ or LDAP to control SNMPv3 user accounts for credentials.
-Thanks Vinod **Rating Encourages contributors, and its really free. **
hello,
are there new informations regard this feature? has anyone successfully configured snmpv3 authentication via radius or tacacs?
kind regards
