Requesting for Syslog config help on ASA
Tarjeet Singh
I am trying to configure Syslog on ASA 5510 and 5505. I just want ASA to sent Syslog message for Warning. while i have only defined trap for Warning. it is still sending message for level 3,2, and 1
In Cisco notes it says
You can specify the severity level number (1 through 7) or name. For example, if you set the severity level to 3, then the ASA send syslog messages for severity levels 3, 2, and 1.
How I can limit my message to just Level to 3 instead of getting 2,1 level at same time..
logging enable
logging timestamp
logging buffer-size 128000
logging trap warnings  ---------------------only trying to send Warning but i am also getting Critical logs in my server
logging asdm informational
logging host inside 10.80.13.42
I also tried to do Class base but it is not sending any messages to syslog
logging enable
logging timestamp
logging list VPN level warnings
logging list VPN level warnings class auth
logging list VPN level warnings class vpn
logging list VPN level warnings class ssl
logging buffered VPN
Please advice. thanks in advance...
Marvin Rhoads
The settings are, as noted in the documentation, inclusive of higher priority messages. The only way (on an ASA)  I know of excluding the Level 1,2 and 3 messages when you are logging Level 4 would be to specifically exclude the individual syslog messages by number.
Why would you not want the higher priority messages?
Marvin Rhoads
My Client only wants to receive message for warning into his external Syslog server so he can track VPN users login if we keep getting Critical logs then it will fill whole server quickly and you wont be able to see login users
Can you please suggest me, how i can exclude syslog level 1,2 and only receive 3
thank you
Probably the easiest way to do what you're asking would be to elevate the severity level (say to "1" = "alert" - see levels here) of the specific messages you are looking for and then making that your global logging level.
If you're getting too many "other" severity 1 messages, you have a much bigger problem than tracking VPN users.
The VPN users login syslog message ID (I don't know the message ID off the top of my head) would be elevated like this example
