reset MIB values
angedibartolo
I'd like to know if there is a CLI command to reset my MIB values (except a reboot).
I saw that a "clear counters" doesn't reset it.
Joe Clarke
The SNMP specification does not allow SNMP counters to be reset unless the agent is rebooted.
So, I had to reboot my switch to reboot the agent? or there is another way to reboot it without rebooting the whole switch?
You have to reboot the switch.
