Resetting pwd for NAM2
robin_goel
I am using NAM2 3.4 with CWLMS 2.5. I have lost my root password, Plz tell me how can i recover that pwd or reset the pwd?
thanks
nhabib
Level 9
Level 9
The password recovery for the NAM is documented at the following location:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/cfgnotes/78_14487.htm#115461
It's really one command on the switch:
"If you forget or lose the password, you can enter the clear module password command from the switch CLI to restore the password for the root account to root and the guest account to guest."
#clear module pc-module 11 password
Failed to clear password
