Restarting switches in NetConfig
ken.gordon
Small issue I'm having when I run an adhoc command in NetConfig sending the command 'reload'. While the switch itself does infact restart, the NetConfig says that the job failed. It says failed as it times-out waiting for a response to the command (of course it does, the switch is restarting!). Is there a specific NetConfig job for reloading?
I'm running IOS updates and would like to restart the switches at a later date, can anyone suggest a solution for me, or perhaps what I'm doing wrong?
miheg
Level 5
Level 5
I think you can use
reload in 0:10
This should stop the job from reporting an error.
To be sure the box rebooted you can check the syslog "reload report"
Cheers,
Michel
galamayur
I think you shud try reload
Mayur
miheg
Level 5
Level 5
I think you can use
reload in 0:10
Cheers,
Michel
This worked perfectly, thanks for your help.
