reverse telnet
troyboswell
Frequent Visitor
Frequent Visitor
I am try to set up a reverse telnet seesion between AUX port of 3725 Router to the console port of a master switch in a 3750 Stack configuration. The configuration on the AUX port is as follows:
line aux 0
exec-timeout 20 0
no exec
transport preferred none
transport input all
transport output all
stopbits 1
And on the Switch side, the configuration is as follows:
line con 0
exec-timeout 60 0
password 7 XXXXXXXXXXXXX
I enter en the foolowing command from the router and I get the following:
telnet X.X.X.X 2097
Trying X.X.X.X, 2097 ...
% Connection refused by remote host
Deleting login session
I have tried using a rollover cable and a straight through cable between the devices but the result is the same. Does anyone have any ideas on how to make this work?
pkhatri
Level 11
Level 11
Can you enter the following on the aux port:
line aux 0
exec
Paresh
I tried that but the results are still the same. Do I have to add anymore detail to "console 0"
