DFM Configuration
bm_5789
Level 5
Level 5
I've installed DFM 2.0 and Common Services 3.0 on a windows 2k server with sp4. I unregistered the daemons and then tried to re-register them according to the Install pdf. I've attached the error that I get. Has anyone seen this before? TIA
a-vazquez
Level 11
Level 11
Please include the file extensions .exe for the pdcmd and brstart commands.
Progra~1\CSCOpx\bin\pdcmd.exe -r DfmBroker -e c:\Progra~1\CSCOpx\objects\smarts\bin\brstart.exe -f
"--output --port=9002 --accept=any --restore=c:\Progra~1\CSCOpx\objects\smarts\conf\broker.rps"
Thank you!!! You're info was absolutely correct.
please rate helpfull information and also if they solved your problem or part of it, because it will be much more easier for others to find good answers and informations!
MArtin
