RME 4.0.6 subinterface baseline template regex issue
bteravsk
I am trying to write a baseline template that will check all of the major interfaces on a router looking for proper NetFlow commands, and checking the subinterfaces making sure no NetFlow is configured on them. I can get the major interfaces to work OK, but the subinterface regex is not working.
My XML output for the serial subinterface check is:
  <Commandlet Name="ActiveSerialSubInt" ControlStmt="false" Parent="Global" Submode="true" Condition="true" Ordered="false">
    <CommandInfo CheckType="2">
      <Command>shutdown</Command>
    </CommandInfo>
    <ContextModeCommand>interface [#Serial(\d|/|:)+\.\d+.*#]</ContextModeCommand>
    <PreCondition>Global</PreCondition>
    <Commandlet Name="NoFlowsOnActiveSub" ControlStmt="false" Parent="ActiveSerialSubInt" Submode="false" Condition="false"
    Ordered="false">
        <Command>ip flow ingress</Command>
      </CommandInfo>
        <Command>ip flow egress</Command>
      </CommandInfo>
        <Command>ip route-cache flow</Command>
      </CommandInfo>
      <ContextModeCommand></ContextModeCommand>
      <PreCondition>ActiveSerialSubInt</PreCondition>
    </Commandlet>
  </Commandlet>
I went to a website that checks Java pattern match strings and it works with the following configuration string:
interface Serial0/0/0.777 point-to-point. I also used a Java application from the tutorials and it found the match as well.
I use something similar to the above for the major serial interfaces which works fine: [#Serial(\d|/|:)+]
Performing a debug (I removed the timestamps, level, and thread information for brevity) on the config job I see the following which is odd as it just skips right over the subinterface, but it does dive into the next major interface returning a false match.
Is there some issues with looking at subinterfaces with CiscoWorks baseline templates?
Any assistance would be appreciated.
Brian
com.cisco.nm.rmeng.dcma.template.comparator.ConfigTemplateComparator,findContextConfiglet,1313,Context command: interface Serial0/0/0.777 point-to-point
com.cisco.nm.rmeng.dcma.template.comparator.TemplatePatternMatcher,checkForPatternMatch,172,Comparing: interface [#Serial(\d|/|:)+\.\d+.*#] and interface Serial0/0/0.777 point-to-point
com.cisco.nm.rmeng.dcma.template.comparator.ConfigTemplateComparator,findContextConfiglet,1313,Context command: interface Serial0/0/1
com.cisco.nm.rmeng.dcma.template.comparator.TemplatePatternMatcher,checkForPatternMatch,172,Comparing: interface [#Serial(\d|/|:)+\.\d+.*#] and interface Serial0/0/1
com.cisco.nm.rmeng.dcma.template.comparator.TemplatePatternMatcher,checkForPatternMatch,206,Comparing: #Serial(\d|/|:)+\.\d+.*# and Serial0/0/1
com.cisco.nm.rmeng.dcma.template.comparator.TemplatePatternMatcher,checkForPatternMatch,236,Comparing: Serial(\d|/|:)+\.\d+.* and Serial0/0/1
com.cisco.nm.rmeng.dcma.template.comparator.TemplatePatternMatcher,checkForPatternMatch,242,Looking for a positive match
com.cisco.nm.rmeng.dcma.template.comparator.TemplatePatternMatcher,checkForPatternMatch,260,actoutput:    false
com.cisco.nm.rmeng.dcma.template.comparator.TemplatePatternMatcher,checkForPatternMatch,280,b:    false
Nael Mohammad
Level 5
Level 5
Try this variable instead "interface [#.*#] [#.*#]" and this should take care of both the interface and subinterface. The syntax you have will only work for serial interface but not the subinterface.
Wrong:
Correct:
or if you want to restrict to serial try the following:
interface [#Serial.*#] [#.*#]
Let me know if it works or not.
