08-11-2005 04:16 AM
I am just checking to see whether anyone else has problems with unsuppported devices in RME4.0
Is there any way to add support for the 1131AG access points in RME or do we have to wait for another patch.
REgards
Miron
08-11-2005 04:41 AM
What is the sysObjectID of the device?
Have you installed RME 4.0.1 yet?
08-11-2005 04:58 AM
Yes I have,
When I go to Verify Device Credentials they are the only devices that constantly fail. When you click on the FAIL it comes up with a box saying device not supported.
Miron
08-11-2005 05:30 AM
Do you happen to know what the sysObjectID is for the devices?
08-11-2005 05:36 AM
How would I find that out
Miron
08-11-2005 05:53 AM
Go to Device Troubleshooting -> Device Center,
select one of the AP's that is not managed
under Tools Click on SNMP Walk
Starting OID: Enter sysObjectID
Select Output OIDs Numerically <-------- Important
Click on OK
08-11-2005 06:21 AM
.1.3.6.1.2.1.1.2.0=OID:.1.3.6.1.4.1.9.1.618
08-11-2005 07:17 AM
Looks like support for this device will be added to RME 4.0.2 (which should be released soon, not sure when).
