RME 4.2 ArchivePurge job failure
yjdabear
It appears every daily ArchivePurge job has failed with the following, since importing the LMS 2.6 backup into 3.1.
/var/adm/CSCOpx/files/rme/jobs/ArchivePurge/1562/334/log
[ Tue Dec 16 01:30:05 EST 2008 ],INFO ,[main],com.cisco.nm.rmeng.config.ccjs.executor.CfgJobExecutor,getJobExecutio
nImpl,160, Executor implementation class com.cisco.nm.rmeng.dcma.jobdriver.DcmaJobExecutor
[ Tue Dec 16 01:30:05 EST 2008 ],FATAL,[main],com.cisco.nm.rmeng.config.ccjs.executor.CfgJobExecutor,<init>,128,Exc
eption occured and Job Terminated abnormally. com/cisco/nm/xms/ogs/util/OGSExceptionjava.lang.NoClassDefFoundError:
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:164)
at com.cisco.nm.rmeng.config.ccjs.executor.CfgJobExecutor.getJobExecutionImpl(CfgJobExecutor.java:164)
at com.cisco.nm.rmeng.config.ccjs.executor.CfgJobExecutor.<init>(CfgJobExecutor.java:114)
at com.cisco.nm.rmeng.config.ccjs.executor.CfgJobExecutor.main(CfgJobExecutor.java:44)
Nothing in dcmaserver.log:
[ Mon Dec 15 22:39:19 EST 2008 ],INFO ,[Thread-1],com.cisco.nm.rmeng.dcma.configmanager.CfgThreadManager,run,96,###
# End of Sweep Mon Dec 15 22:39:19 EST 2008 ####
[ Tue Dec 16 09:05:10 EST 2008 ],INFO ,[Thread-4],com.cisco.nm.rmeng.dcma.configmanager.ConfigManager,updateArchive
,489,Update ALL request for 1 devices - Syslog triggered Config Collection
tail -f configjobs.log
[ Mon Dec 15 05:30:03 EST 2008 ],INFO ,[main],com.cisco.nm.rmeng.common.VerifyRMELicense,validate,?,
[ Tue Dec 16 01:30:02 EST 2008 ],INFO ,[main],com.cisco.nm.rmeng.config.ccjs.executor.CfgJobExecutor,<init>,75,Job Id 1562 obtained
[ Tue Dec 16 01:30:04 EST 2008 ],INFO ,[main],com.cisco.nm.rmeng.config.ccjs.executor.CfgJobExecutor,<init>,88, get info hist done
[ Tue Dec 16 01:30:04 EST 2008 ],INFO ,[main],com.cisco.nm.rmeng.config.ccjs.executor.CfgJobExecutor,<init>,90,Job ID: 1562 Job Type :ArchivePurge
[ Tue Dec 16 01:30:04 EST 2008 ],INFO ,[main],com.cisco.nm.rmeng.common.VerifyRMELicense,validate,?,sun.misc.Launcher$AppClassLoader@a9c85c
[ Tue Dec 16 01:30:05 EST 2008 ],INFO ,[main],com.cisco.nm.rmeng.common.VerifyRMELicense,validate,?,
I did have debug on for IC_Server, but I'm not sure it has nothing to do with that.
Joe Clarke
This looks like a bug of mine. It should be fixed in RME 4.2, but you will need to remove this job, and reschedule it.
Do I "remove" it by disabling then re-enabling it, or would I have to delete it from Job Management completely and start anew?
Disabling it, and re-enabling it should be sufficient.
