RME/compliance mgmt - deploy ntp
lanwancig1
Beginner
Beginner
Using RME 4.3.0
I'm trying to deploy new ntp settings across all network infrastructure. I prepare baseline template and check complance. When i try to deploy i'v got this issue:
Job finished sucessfully, but some of devices are still in pending state. All of this devices "wating" for deploy this command:
no ntp server X.X.X.X key 1 prefer
My template looks like this:
+   ntp   server   A.A.A.A
+   ntp   server   B.B.B.B
[#ntp   server   (?!A.A.A.A|B.B.B.B).*#]
Is there any way to change this bahavior? To generate simply: "no ntp server X.X.X.X" instead of "no ntp server X.X.X.X key 1 prefer" while complance check?
Gaganjeet Chug
Enthusiast
Enthusiast
HI,
This error states that "but some of devices are still in pending state". So, kindly check if you have any device showing under " Pending Devices" category.
Kindly go to RME > Devices. Post the screenshot of this location here.
Gaganjeet
Recognize Your Peers
