RME device package for asa 5520
thetnaing00
hi,
anyone know which device package i need to load for rme to save archive for asa 5520.i saw the rme4.0 device package but there is not 5520,there is only 5510 and others.is it the same? can i use asa.rme40.v4.0 for 5520 as well. thanks for your reply.
David Stanford
The package you are referring to is for RME 4.1
The ASA 5520 is supported in RME 4.0.5 though (dev pkg ASA.RME40.v2-0.zip):
http://cisco.com/en/US/products/sw/cscowork/ps2073/products_device_support_table09186a008073ebe3.html#wp231589
David Stanford
