Rommon mode issue
saroopmalhi
Community Member
Can any one help me out to get off form roomon mode.
Actually i changed the confreg 0x2102 to 0x2142 vlaue and then i get into the switch and configured it properly and save the configuration and reload the switch. And i forgot to set the confreg 0x2102 vlaue and i got struck in rommon mode.Even i no of time reboot or reset this but still over their in rommon mode. Switch model # WS-6509.
I apprecaite your help.
Vinod Arya
Set the configuration register with the confreg command if the router is in ROMmon mode:
rommon 1 >confreg 0x2102
Than you can use boot command to boot from there or boot followed by image name with path, like :
boot disk0:<image_name>.bin
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Marvin Rhoads
Have you had a look at the Recovering from ROMMON mode document?
Generally you can just type type "confreg 0x2102" from rommon and make sure the image is present on bootflash and then boot.
