Router security settings!
chunhyungjoon
Hello, I'm using Cisco 2811 and want to make some security settings.
How can I make the router able to connect via ssh and deny telnet?
And how can I route between 2811 and Debian Linux via osph area10?
Thanks.
Kasiraman S
Check if the SSH is already configured or not. If yes, use the below command in the VTY.
line vty 0 4
transport input ssh
If ssh is not configured. use the below
crypto key generate rsa 1024
ip ssh version 2
OSPF config for Router and I'm not sure about the Linux side.
router ospf 10
network A.B.C.D area 10
For more information on OSPF pelase refer the guide.
http://www.cisco.com/en/US/docs/ios/12_0/np1/configuration/guide/1cospf.html
Do rate helpful post.
Kasi
