08-12-2017 11:53 AM
I know my config is messy, I have tried everything I can think of to get this to work.
Could someone tell me why my vlans will not route to the internet?
(Also if you see anything that needs to be removed I would welcome that too)
870 Router
Current configuration : 4095 bytes
! Last configuration change at 18:06:58 UTC Sat Aug 3 2002 by cgarlick
version 15.1
no service pad
service password-encryption
hostname AvatarRt01
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXXXXXXXXXXXXX
enable password 7 XXXXXXXXXXXXXXXXXXXXX
no aaa new-model
no process cpu autoprofile hog
dot11 syslog
ip source-route
ip dhcp excluded-address 10.0.10.1
ip dhcp excluded-address 10.0.20.1
ip dhcp excluded-address 10.0.30.1
ip dhcp excluded-address 10.0.40.1
ip dhcp excluded-address 10.0.10.2
ip dhcp excluded-address 10.0.20.2
ip dhcp excluded-address 10.0.30.2
ip dhcp excluded-address 10.0.40.2
ip dhcp pool Vlan1_DHCP
network 10.0.10.0 255.255.255.0
default-router 10.0.10.1
dns-server 8.8.8.8 8.8.4.4
domain-name Avatar.public
ip dhcp pool Vlan2_DHCP
network 10.0.20.0 255.255.255.0
default-router 10.0.20.1
ip dhcp pool Vlan3_DHCP
network 10.0.30.0 255.255.255.0
default-router 10.0.30.1
ip dhcp pool Vlan4_DHCP
network 10.0.40.0 255.255.255.0
default-router 10.0.40.1
ip cef
ip domain name AvatarDomain.local
vtp domain AvatarDomain.local
vtp mode transparent
username cgarlick privilege 15 password 7 XXXXXXXXXXXXXXXXX
vlan 2
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
mac-address 000f.8f38.6289
ip address 24.49.13.49 255.255.254.0
duplex auto
speed auto
interface Vlan1
ip address 10.0.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 24.49.12.1
ip access-list extended Internet
permit ip 10.0.0.0 0.0.0.255 any
access-list 1 permit any
snmp-server community Avatar_RT01_SNMP RO
control-plane
line con 0
logging synchronous
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
password 7 XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
login local
transport input all
scheduler max-task-time 5000
end
3550 Switch
Current configuration : 5200 bytes
version 12.2
no service pad
hostname AvatarSW1
enable secret 5 XXXXXXXXXXXXXXXXXXXXXXXX
enable password 7 XXXXXXXXXXXXXXXXXXXXXXXXXXXXX
username cgarlick password 7 XXXXXXXXXXXXXXXXXXXXXXXXXX
no aaa new-model
ip subnet-zero
ip routing
ip domain-name Avatar-Switch
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
interface FastEthernet0/1
description To 870 router
switchport mode dynamic desirable
spanning-tree portfast
interface FastEthernet0/2
switchport mode access
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
switchport access vlan 2
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
switchport access vlan 3
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
switchport access vlan 4
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 10.0.10.2 255.255.255.0
interface Vlan2
ip address 10.0.20.2 255.255.255.0
interface Vlan3
ip address 10.0.30.2 255.255.255.0
interface Vlan4
ip address 10.0.40.2 255.255.255.0
ip classless
ip route 10.0.0.0 255.0.0.0 10.0.10.1
ip http server
control-plane
line con 0
logging synchronous
login local
line vty 0 4
password 7
login local
transport input ssh
line vty 5 15
login
end
08-13-2017 01:57 AM
If you want the VLAN traffic to access the Internet via the router then your switch needs to route "0.0.0.0" to it - you currently have an incorrect route for 10.0.0.0.
To use the router as your DHCP server the switch's VLAN interfaces need an ip helper statement referencing the router's address.
Finally, your NAT is incompletely setup. Here's a good short article on setting it up:
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/260-cisco-router-nat-overload.html
You don't have the ip nat outside interface defined or the ip nat statement with ACL referenced as described in the article I linked.
