RPC Argument Passing
Jason Rossiter
I am trying to set up an RPC detector that runs an applet. The Applet currently just contains CLI commands, but I would like to use arguments passed from the SOAP request in the CLI commands. From the RPC syntax, the following should be accepted:
<?xml version="1.0"?>
<SOAP:Envelope xmlns:SOAP="http://www.cisco.com/eem.xsd">
<SOAP:Body>
  <run_emscript>
    <script_name> name of script </script_name>
    <argc> argc value </argc>
    <arglist>
    <l> argv1 value </l>
    <l> argv2 value </l>
    <l> argvn value </l>
    </arglist>
  </run_Eemscript>
</SOAP:Body>
</SOAP:Envelope>
My simple message is as follows:
<?xml version="1.0" encoding="UTF-8"?>
  <SOAP:Body>
    <run_eemscript>
      <script_name>Event_RPC</script_name>
      <argc> argc test </argc>
      <arglist>
           <l> argv1 100</l>
       </arglist>
    </run_eemscript>
  </SOAP:Body>
</SOAP:Envelope>
However, whenever the <arglist> is included I receive an error code response. I would expect the arglist to be accepted and an action command something like the following to be accepted:
action 1.0 cli command "switchport access vlan $_rpc_arg1"
Has anyone had experience with this?
Jason
That's an (ell) not a <1>.  Your arguments are:
100
200
Joe Clarke
You need to omit the "argc" and "argv" literals.  Your SOAP message will look like:
      Event_RPC
Remember, argc is a count of the number of arguments.  You should also look at my Perl API for this.  It makes doing a lot of these things much easier.
https://supportforums.cisco.com/docs/DOC-19523
I have tried the suggestion, but now receive the following response:
      Event_RPC
        <1>100
        <2>200
got data:
"http://www.cisco.com/eem.xsd\">-15844577'Embedded Event Manager' detected the 'fatal' condition 'unknown event ID']]>]]>\r\n"
100
200
Thats it.
Jason
